Routes
A route is a path from your current location to one or more destinations.
  • The device calculates a recommended route to your destination based on the preferences you set, including the route calculation mode (Changing the route calculation mode) and avoidances (Avoiding Delays, Tolls and Areas).
  • The device can automatically avoid roads that are not appropriate for the active vehicle profile.
  • You can start navigating to your destination quickly using the recommended route, or you can select an alternative route (Starting a route).
  • If there are specific roads you need to use or avoid, you can customise the route.
  • You can add multiple destinations to a route (Adding a location to your route).
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
