Installing a memory card for maps and data
You can install a memory card to increase the storage space for maps and other data on your device. You can purchase memory cards from an electronics supplier, or go to www.garmin.com/maps to purchase a memory card with pre-loaded Garmin® mapping software. The device supports microSD® memory cards from 4 to 32 GB. Memory cards must use the FAT32 file system format. Memory cards greater than 32 GB must be formatted using the device (Formatting the Memory Card).
  1. Locate the map and data memory card slot on your device (Display Overview).
  2. Insert a memory card into the slot.
  3. Press it in until it clicks.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
