Color Gauges and Running Dynamics Data
The running dynamics screen displays a color gauge for the primary metric. You can customize the primary metric. The color gauge shows you how your running dynamics data compare to those of other runners. The color zones are based on percentiles.
Garmin® has researched many runners of all different levels. The data values in the red or orange zones are typical for less experienced or slower runners. The data values in the green, blue, or purple zones are typical for more experienced or faster runners. More experienced runners tend to exhibit shorter ground contact times, lower vertical oscillation, lower vertical ratio, lower step speed loss, and higher cadence than less experienced runners. However, taller runners typically have slightly slower cadences, longer strides, and slightly higher vertical oscillation. Vertical ratio is your vertical oscillation divided by stride length. It is not correlated with height.
Go to garmin.com/runningdynamics for more information on running dynamics. For additional theories and interpretations of running dynamics data, you can search reputable running publications and websites.
Color Zone
Percentile in Zone
Cadence Range
Ground Contact Time Range
Step Speed Loss Range
Purple Purple
>95
>185 spm
<218 ms
<8.2 cm/s
Blue Blue
70–95
174–185 spm
218–248 ms
8.2-12.1 cm/s
Green Green
30–69
163–173 spm
249–277 ms
12.2-19.7 cm/s
Orange Orange
5–29
151–162 spm
278–308 ms
19.8-25.9 cm/s
Red Red
<5
<151 spm
>308 ms
>25.9 cm/s
GUID-2DA54DF8-8084-40ED-954F-EDA09C13B47F v6
September 2026
