Editing a Profile
Before you edit a profile, you must first make the profile your current profile (Selecting a Different Profile).
  1. From the Applied Ballistics® app, press GPS.
  2. Select Profile.
  3. If necessary, select Profile, select a profile, select Edit Name, and enter a new name.
  4. Select Bullet Data, and enter the bullet properties.
    TIP: You can select Bullet Library to automatically enter bullet properties from the Applied Ballistics bullet database. If you manually enter the bullet properties, you can find the information on the bullet manufacturer's website.
  5. Select Gun Data, and select an option.
    NOTE: Some options only appear when you enable the Sight in Condition option.
  6. If necessary, select Gun Data > Advanced Settings, and select an option:
    • To calibrate the muzzle velocity to provide a more accurate solution in the supersonic range for your firearm, select Calibrate Muzzle Velocity, and select an option.
    • To calibrate the custom drag factor, select Calibrate Custom Drag Factor and select an option.
    • To calibrate the drop scale factor to provide a more accurate solution at or beyond the transonic range for your firearm, select Calibrate DSF, and select an option.
      NOTE: Garmin® recommends you calibrate the muzzle velocity prior to the drop scale factor. After you calibrate the drop scale factor, you can select View DSF Table to view the drop scale factor table. If necessary, you can hold MENU and select Clear DSF Table to reset the drop scale factor table to the default values.
    • To edit the muzzle velocity temperature table, select MV Temp Table, hold MENU, select Edit, select a value to edit, press GPS and enter the value.
      NOTE: If necessary, you can hold MENU and select Clear MV-Temp to reset the muzzle velocity temperature table back to the default values.
  7. Select Output Units, and select the units of measure.
GUID-2C274FD2-F0C3-445C-B0AC-700FECCE12E9 v6
September 2026
