Adding Contacts
You can add up to 50 contacts to the Garmin Connect™ app. Contact emails can be used with the LiveTrack feature. Three of these contacts can be used as assistance contacts (Adding Assistance Contacts).
  1. From the Garmin Connect app, select Menu.
  2. Select Contacts.
  3. Follow the on-screen instructions.
After you add contacts, you must sync your data to apply the changes to your Instinct® 3 device (Using the Garmin Connect App).
GUID-2C274FD2-F0C3-445C-B0AC-700FECCE12E9 v7
November 2026
