Altimeter Settings
Hold MENU, and select Sensors & Accessories > Altimeter.
Calibrate
Manually calibrates the altimeter sensor.
Auto Cal.
Self-calibrates the altimeter each time you use satellite systems.
Sensor Mode
Sets the mode for the sensor. The Auto option uses both the altimeter and barometer according to your movement. You can use the Altimeter Only option when your activity involves changes in altitude, or the Barometer Only option when your activity does not involve changes in altitude.
Elevation
Sets the units of measure for elevation.
GUID-2C274FD2-F0C3-445C-B0AC-700FECCE12E9 v7
November 2026
