Wireless Sensors
Your watch can be paired and used with wireless sensors using ANT‍+® or Bluetooth® technology (Pairing Your Wireless Sensors). After the devices are paired, you can customize the optional data fields (Customizing the Data Screens). If your watch was packaged with a sensor, they are already paired.
For information about specific Garmin® sensor compatibility, purchasing, or to view the owner's manual, go to buy.garmin.com for that sensor.
Sensor Type
Description
Applied Ballistics
You can use Applied Ballistics® devices, such as rangefinders or wind sensors, and view additional ballistics information on your watch.
Club Sensors
You can use Approach® CT10 golf club sensors to automatically track your golf shots, including location, distance, and club type.
DogTrack
Allows you to receive data from a compatible handheld dog tracking device.
eBike
You can use your watch with your eBike and view bike data, such as battery and range information, during your rides.
Extended Display
You can use the Extended Display mode to display data screens from your watch on a compatible Edge® bike computer during a ride or triathlon.
External Heart Rate
You can use an external sensor, such as the HRM 200, HRM 600, HRM‍-Fit™, or HRM-Pro™ series heart rate monitor, to view heart rate data during your activities.
Foot Pod
You can use a foot pod to record pace and distance instead of using GPS when you are training indoors or when your GPS signal is weak.
inReach
The inReach® remote function allows you to control your inReach satellite communicator using your Instinct® watch (Using the inReach Remote).
Lights
You can use Varia™ smart bike lights to improve situational awareness.
PC
You can play video games on your computer and see real-time statistics on your device (Using the Garmin GameOn App).
Power
You can use the Rally™ or Vector™ power meter bike pedals to view your power data on your watch. You can adjust your power zones to match your goals and abilities (Setting Your Power Zones), or use range alerts to be notified when you reach a specified power zone (Setting an Alert).
Radar
You can use a Varia rearview bike radar to improve situational awareness and send alerts about approaching vehicles.
RD Pod
You can use a Running Dynamics Pod to record running dynamics data and view it on your watch (Running Dynamics).
Smart Trainer
You can use your watch with an indoor bike smart trainer to simulate resistance while following a course, ride, or workout (Using an Indoor Trainer).
Speed/Cadence
You can attach speed or cadence sensors to your bike and view the data during your ride. If necessary, you can manually enter your wheel circumference (Wheel Size and Circumference).
Tempe
You can attach the tempe™ temperature sensor to a secure strap or loop where it is exposed to ambient air, so it provides a consistent source of accurate temperature data.
Vectronix
You can use Vectronix® rangefinders, and view additional ballistics information on your watch.
VIRB
The VIRB® remote function allows you to control your VIRB action camera using your watch (VIRB Remote).
Xero Chronograph
You can pair with a Xero® chronograph to access session controls and view ballistics data (Using the Xero Chronograph App).
XERO Laser Locations
You can view and share laser location information from a Xero device (Xero Laser Location Settings).
GUID-2C274FD2-F0C3-445C-B0AC-700FECCE12E9 v5
May 2026
