Connecting the Device to a Wireless Access Point Using Wi‑Fi Protected Setup
If it is supported by your wireless access point, you can connect this device using Wi‑Fi® Protected Setup (WPS) instead of manually selecting the SSID and entering the password.
NOTE: You may need to see the owner's manual for your wireless access point for information about enabling WPS.
  1. Select Menu symbol > SETTINGS > NETWORK > WI-FI CLIENT > WPS.
  2. Enable the WPS connection on your wireless access point.
NOTE: When you connect the stereo to a wireless access point, you cannot use the wired network connection.
GUID-2BF6BEB7-4CE7-4804-9935-F0D912E72FA7 v4
January 2026
