Updating the Software Using a USB Flash Drive
You can update the device software using a USB flash drive. You can prepare a suitable USB flash drive by manually downloading and loading the update files, or you can use the Garmin Express™ app.
NOTICE
Do not turn off the device or disconnect the power during a software update. Turning off the power during a software update may cause the device to become unresponsive.
NOTE:
  • You cannot update the software using a USB flash drive formatted using the NTFS file system. If you encounter problems updating the device, format the USB flash drive using FAT32 and try the update process again.
  • The device may restart a few times while updating the software. This is expected behavior.
  • You can program only newer versions of software on the device.
  • You can download an entertainment package to update all Fusion Apollo™ stereos connected as part of an entertainment network using Ethernet cables and any Garmin Spectra™ lighting controllers connected to the same NMEA 2000® network as the stereo.
  • If you have different stereo models connected, you should start an entertainment package update from the newest stereo, such as the MS-RA800. The newest stereo can update all older stereo models, while an older stereo model may not be able to update a newer model.
NOTE: If the stereo you want to update is in a group, you must remove it from the group (Leaving a Group).
  1. Select an option to prepare the USB flash drive for updating the stereo software:
  2. After you prepare the USB flash drive with the software-update files, insert the USB flash drive into the stereo and use the stereo interface to proceed with the update (Updating the Software from a Prepared USB Flash Drive).
GUID-2BF6BEB7-4CE7-4804-9935-F0D912E72FA7 v4
January 2026
