Stereo Webpage
When you connect the stereo to a network containing a mobile device or a personal computer, you can use the web browser on the mobile device or personal computer to view selected information about the stereo, adjust a limited collection of settings, and update the stereo software.
Parent Topic: Appendix
Accessing the Stereo Webpage
- Connect the stereo to a network using a wired Ethernet or a Wi‑Fi® connection.
- If necessary connect a personal computer or a mobile device to the same network as the stereo.
Locate the IP address of the stereo:
If the stereo is connected using a wired Ethernet connection, select
If the stereo is connected through a Wi‑Fi connection, select
- In the address bar of a web browser on the connected personal computer or mobile device, enter "http://" followed by the IP address of the stereo.
The browser on your PC or mobile device opens the stereo webpage.
Updating the Stereo from the Stereo Webpage
It is recommended to update the stereo using theFusion® app, a USB drive, or the Garmin® network. If you prefer not to use one of the recommended update methods, you can update the stereo using the webpage.
