Specifications
Dimensions (H×W×D)
164.8 × 71.8 × 21.4 mm (6.5 × 0.8 × 0.9 in.)
Weight
235 g (0.52 lb.)
Operating temperature range
From -20° to 55°C (from -4° to 131°F)
Storage temperature range
From -25° to 70°C (from -13° to 158°F)
Compass-safe distance
80 cm (31.5 in.)
Water rating
IEC 60529 IPX81
Power supply
From 10.8 to 32 VDC
Maximum power
12 W (1 A at 12 V)
Fuse amperage
2 A
Sound output
3W Class D amplifier, THD < 5% @ 85dBA
EU SAR
0,01 W/kg torso, 0,07 W/kg limb
Battery type
Lithium Polymer
Battery life
10 hours2
Charge time
2 hours
1 The device withstands incidental exposure to water of up to 2 m for up to 60 min. For more information, go to garmin.com/waterrating.
2 Battery life estimate reflects typical usage. Actual battery life depends on volume and display brightness settings and how often the speaker is used.
GUID-2ABCE486-B16E-40BF-A499-7C9A3FAE23AF v1
May 2025
