Important Safety Information
See the Important Safety and Product Information guide in the product box for product warnings and other important information.
Failure to install this device according to these instructions could result in personal injury, damage to the vessel or device, or poor product performance.
To avoid possible personal injury or damage to the device and vessel, disconnect the vessel's power supply before beginning to install the device.
When connecting the power cable to the power supply, you must install an inline fuse or circuit breaker (not included), as listed in the product specifications, to prevent the possibility of personal injury or product damage caused by fire or overheating. Connecting the power cable without adequate circuit protection voids the product warranty.
To avoid possible personal injury, always wear safety goggles, ear protection, and a dust mask when drilling, cutting, or sanding.
To avoid damage to your boat, this device should be installed by a qualified marine installer. Specific knowledge of marine electrical systems is required for proper installation.
When drilling or cutting, always check what is on the opposite side of the surface to avoid damaging the vessel.
If you are mounting the device in fiberglass, when drilling the pilot holes, use a countersink bit to drill a clearance counterbore through only the top gel-coat layer. This will help to avoid cracking in the gel-coat layer when the screws are tightened.
