Mounting Considerations
When selecting a mounting location, observe these considerations.
NOTICE
You must select a mounting location that protects the charging cradle from exposure to water. Exposure to water can cause the charging contacts on the cradle and the handset to corrode, leading to product damage and malfunction.
  • To route the charging cradle power cable through the bulkhead, you must select a mounting location with at least 60 mm (212/32 in.) of clearance behind the bulkhead.
  • You must select a mounting location that is within range of the Wi‑Fi® network used to connect to the Cortex® hub1.
1 The Cortex hub can broadcast its own Wi‑Fi network or it can use the boat's Wi‑Fi network to connect to Cortex handsets and the Cortex Onboard™ app. See the Cortex hub Owner's Manual for more information.
GUID-2ABCE486-B16E-40BF-A499-7C9A3FAE23AF v1
May 2025
