Wireless Sensors
Your Edge® bike computer can be paired and used with wireless sensors using ANT+® or Bluetooth® technology (Pairing Your Wireless Sensors). After the devices are paired, you can customize the optional data fields (Adding a Data Screen).
For information about specific Garmin® sensor compatibility, purchasing, or to view the owner's manual, go to garmin.com for that sensor.
Sensor Type |
Description |
eBike |
You can use your device with your eBike, such as the Bosch® Smart System or Shimano® eBike system, and view bike data, such as battery and shifting information, during your rides (Viewing eBike Sensor Details). |
Edge Remote |
You can control your Edge bike computer with the Edge remote, including starting the activity timer, marking laps, and scrolling through data screens. |
Extended Display |
You can use the Extended Display mode to display data screens from your compatible Garmin watch on a compatible Edge bike computer during a ride or triathlon (Setting Up Extended Display Mode). |
Heart Rate |
You can use an external sensor, such as the HRM 200, HRM 600, HRM-Dual™, HRM-Fit™, or HRM-Pro™ series heart rate monitor, to view heart rate data during your activities. You can also broadcast heart rate data from your Garmin compatible watch and view it on your paired Edge bike computer (Broadcasting Heart Rate Data). |
inReach |
The inReach® remote function allows you to control your inReach satellite communicator using your Edge bike computer (Using the inReach Remote). |
Lights |
You can use Varia™ smart bike lights to improve situational awareness. With a Varia headlight camera, you can also take photos and record video during a ride (Using the Varia Camera Controls). |
Power |
You can use the Rally™ or Vector™ power meter bike pedals to view power data on your device. You can adjust the power zones to match your goals and abilities (Setting Your Power Zones), or use range alerts to be notified when you reach a specified power zone (Setting Range Alerts). |
Radar |
You can use a Varia rearview bike radar to improve situational awareness and send alerts about approaching vehicles. With a Varia radar camera tail light, you can also take photos and record video during a ride (Using the Varia Camera Controls). |
Smart Trainer |
You can use your bike computer with an indoor bike smart trainer to simulate resistance while following a course or ride (Using an Indoor Trainer). |
Speed/Cadence |
You can attach speed or cadence sensors to your bike and view the data on your bike computer during your ride. If necessary, you can manually enter your wheel circumference (Wheel Size and Circumference). |
Tempe |
You can attach the tempe™ temperature sensor to a secure strap or loop where it is exposed to ambient air, so it provides a consistent source of accurate temperature data. |
VIRB |
The VIRB® remote function allows you to control your VIRB action camera using your bike computer. |
