Using the inReach Remote
Before you can use the inReach® remote function, you must pair your inReach satellite communicator (Pairing Your Wireless Sensors), then add the inReach glance to the glances list (Customizing the Glances List).
  1. Turn on the inReach satellite communicator.
  2. On your Enduro™ watch, press Lower-left button from the watch face to view the inReach glance.
  3. Press Upper-right button to search for your inReach satellite communicator.
  4. Press Upper-right button to pair your inReach satellite communicator.
  5. Press Upper-right button, and select an option:
    • To send an SOS message, select Initiate SOS.
      NOTE: You should only use the SOS function in a real emergency situation.
    • To send a text message, select Messages > New Message, select the message contacts, and enter the message text or select a quick text option.
    • To send a check-in message, select Send Check-in, and select a message from the list.
    • To view the timer and distance traveled during an activity, select Tracking.
GUID-25EFCCBC-D0EB-4E1B-AE9F-B4B900891C20 v1
October 2026
