Editing an Alarm
Select an option:
From the watch face, hold
From the watch face, press
Hold
- Select .
- Select an alarm.
Select an option:
To turn the alarm on or off, select Status.
To change the alarm time, select Time.
To set an alarm to gently wake you in the 30-minute window before your scheduled alarm based on optimal sleep timing, select Smart Wake.
NOTE: Your alarm will always go off at your selected time in addition to any earlier alarms. For example, if you set your alarm for 8:00 am, the alarm may gently alert you to wake up some time between 7:30 and 8:00 am. -
To set the alarm to repeat regularly, select Repeat, and select when the alarm should repeat.
To select the type of alarm notification, select Sound & Vibe.
NOTE: You can also preview the alarm sound, adjust the volume, and select vibration options. You can select Quiet Start if you want your alarm to start quietly and then get louder. -
To select a description for the alarm, select Label.
Select an option:
To save your edits, select Done.
To delete the alarm, select Delete.
Parent Topic: Setting an Alarm
