Activities and App Settings
These settings allow you to customize each preloaded activity app based on your needs. For example, you can customize data pages and enable alerts and training features. Not all settings are available for all activity types.
From the watch face, hold , select
, select an activity, and select the activity settings.
- 3D Distance
Calculates your distance traveled using your elevation change and your horizontal movement over ground.
- 3D Speed
Calculates your speed using your elevation change and your horizontal movement over ground (3D Speed and Distance).
- Accent Color
Sets the accent color of each activity to help identify which activity is active.
- Add Activity
Allows you to customize a multisport activity.
- Alerts
Sets the training or navigation alerts for the activity.
- Auto Climb
Enables the device to detect elevation changes automatically using the built-in altimeter (Enabling Auto Climb).
- Auto Lap
Sets the options for the Auto Lap® feature (Auto Lap).
- Auto Pause
Sets the device to stop recording data when you stop moving or when you drop below a specified speed (Enabling Auto Pause).
- Auto Rest
Enables the device to automatically detect when you are resting during a pool swim and create a rest interval (Auto Rest).
- Auto Run
Enables the device to detect ski runs automatically using the built-in accelerometer.
- Auto Scroll
Enables you to move through all of the activity data screens automatically while the timer is running (Using Auto Scroll).
- Auto Set
Enables the device to start and stop exercise sets automatically during a strength training activity.
- Background Color
Sets the background color of each activity to black or white.
- ClimbPro
Displays ascent planning and monitoring screens while navigating.
- Countdown Start
Enables a countdown timer for pool swimming intervals.
- Data Screens
Enables you to customize data screens and add new data screens for the activity (Customizing the Data Screens).
- Edit Weight
Allows you to add the weight used for an exercise set during a strength training or cardio activity.
- GPS
Sets the mode for the GPS antenna (Changing the GPS Setting).
- Grading System
Sets the grading system for rating the route difficulty for rock climbing activities.
- Lane Number
Enables you to select a lane number for a track run.
- Lap Key
Enables you to record a lap or a rest during the activity.
- Lock Keys
Locks the keys during multisport activities to prevent accidental key presses.
- Metronome
Plays tones at a steady rhythm to help you improve your performance by training at a faster, slower, or more consistent cadence (Using the Metronome).
- Pool Size
Sets the pool length for pool swimming (Setting the Pool Size).
- Power Averaging
Controls whether the device includes zero values for power data that occur when you are not pedaling.
- Power Save Timeout
Sets the power-save timeout options for the activity (Power Save Timeout Settings).
- Record VO2 Max.
Enables VO2 max. recording for trail run and ultra run activities (Turning Off VO2 Max. Recording).
- Rename
Sets the activity name.
- Repeat
Enables the Repeat option for multisport activities. For example, you can use this option for activities that include multiple transitions, such as a swimrun.
- Restore Defaults
Allows you to reset the activity settings.
- Route Stats
Enables route statistics tracking for indoor climbing activities.
- Segment Alerts
Enables prompts that alert you to approaching segments.
- Self Evaluation
Sets how often you evaluate your perceived effort for the activity (Enabling Self Evaluation).
- Stroke Detect.
Enables stroke detection for pool swimming.
- Swimrun Auto Sport Change
Allows you to automatically transition between the swim portion and the run portion of a swimrun multisport activity.
- Transitions
Enables transitions for multisport activities.
- Vibration Alerts
Enables alerts that notify you to inhale or exhale during a breathwork activity.
- Workout Videos
Enables instructive workout animations for a strength, cardio, yoga, or Pilates activity. Animations are available for workouts downloaded from Garmin Connect™.
- Customizing the Data Screens
- Adding a Map to an Activity
- Alerts
- Auto Lap
- Enabling Auto Pause
- Enabling Auto Climb
- Enabling Self Evaluation
- 3D Speed and Distance
- Using Auto Scroll
- Changing the GPS Setting
- Power Save Timeout Settings
