Tips for Missing Running Dynamics Data
If running dynamics data does not appear, you can try these tips.
  • Make sure you have a running dynamics accessory, such as the HRM-Pro™ accessory.
    Accessories with running dynamics have Running man on the front of the module.
  • Pair the running dynamics accessory with your watch again, according to the instructions.
  • If you are using the HRM-Pro accessory, pair it with your watch using ANT‍+® technology, rather than Bluetooth® technology.
  • If the running dynamics data display shows only zeros, make sure the accessory is worn right-side up.
    NOTE: Ground contact time and balance appears only while running. It is not calculated while walking.
Copyright © Garmin. All rights reserved.GUID-2366BA73-C5B3-4189-B75F-EFA9B2402BD5 v5
