Showing and Hiding Map Data
If you have multiple maps installed on your device, you can choose the map data to show on the map.
  1. From the watch face, press START.
  2. Select Map.
  3. Hold MENU.
  4. Select the map settings.
  5. Select Map > Configure Maps.
  6. Select a map to activate the toggle switch, which shows or hides the map data.
Copyright © Garmin. All rights reserved.GUID-2366BA73-C5B3-4189-B75F-EFA9B2402BD5 v5
