Deleting Files
NOTICE
If you do not know the purpose of a file, do not delete it. Your device memory contains important system files that should not be deleted.
  1. Open the Garmin drive or volume.
  2. If necessary, open a folder or volume.
  3. Select a file.
  4. Press the Delete key on your keyboard.
    NOTE: Mac® operating systems provide limited support for MTP file transfer mode. You must open the Garmin drive on a Windows® operating system. You should use the Garmin Express™ application to remove music files from your device.
Copyright © Garmin. All rights reserved.GUID-2366BA73-C5B3-4189-B75F-EFA9B2402BD5 v5
