Changing the Map Theme
You can change the map theme to display map data optimized for your activity type. For example, high contrast map themes provide better visibility in challenging environments, and activity-specific map themes display the most important map data at-a-glance.
  1. Start an outdoor activity.
  2. Hold MENU.
  3. Select the activity settings.
  4. Select Map > Map Theme.
  5. Select an option.
Copyright © Garmin. All rights reserved.GUID-2366BA73-C5B3-4189-B75F-EFA9B2402BD5 v5
