Using ClimbPro
The ClimbPro feature helps you manage your effort for the upcoming climbs on a course. You can view climb details, including gradient, distance, and elevation gain, before or in real time while following a course. Cycling climb categories, based on length and gradient, are indicated by color.
  1. Hold MENU.
  2. Select Activities & Apps.
  3. Select an activity.
  4. Select the activity settings.
  5. Select ClimbPro > Status > When Navigating.
  6. Select an option:
    • Select Data Field to customize the data field that appears on the ClimbPro screen.
    • Select Alert to set alerts at the start of a climb or at a certain distance from the climb.
    • Select Descents to turn descents on or off for running activities.
    • Select Climb Detection to choose the types of climbs detected during cycling activities.
  7. Review the climbs and course details for the course (Viewing or Editing Course Details).
  8. Start following a saved course (Navigating to a Destination).
Copyright © Garmin. All rights reserved.GUID-2366BA73-C5B3-4189-B75F-EFA9B2402BD5 v5
