Mounting and Powering the Garmin DriveCam Device in Your Vehicle
WARNING
This product contains a lithium-ion battery. To prevent the possibility of personal injury or product damage caused by battery exposure to extreme heat, store the device out of direct sunlight.
Before you use your device on battery power, you should charge it.
  1. Press the suction cup to the windscreen, and flip the lever Call-out number one back toward the windscreen.
    Device mount with callouts
  2. Plug the vehicle power cable into the USB port Call-out number two on the device.
    Device connected to power with callouts
  3. Plug the other end of the vehicle power cable Call-out number three into a power outlet in your vehicle.
  4. Fit the tab on the bottom of the mount into the slot Call-out number four on the back of the device, and press the device into the mount until it clicks.
    Device connecting to the mount
GUID-234ECA7B-7147-4142-80ED-C81970D02FF1 v4
September 2024
