Recording Statistics
Before you can record statistics, you must enable statistics tracking (Enabling Statistics Tracking).
  1. From the scorecard, select a hole.
  2. Enter the total number of strokes taken, including putts, and press OK.
  3. Set the number of putts taken, and press OK.
    NOTE: The number of putts taken is used for statistics tracking only and does not increase your score.
  4. If necessary, select an option:
    NOTE: If you are on a par 3 hole or using Approach® CT10 sensors, fairway information does not appear.
    • If your ball hit the fairway, select In Fairway.
    • If your ball missed the fairway, select Missed Left or Missed Right.
  5. If necessary, enter the number of penalty strokes.
Copyright © Garmin. All rights reserved.GUID-20B1A0A2-73B9-4655-8848-D21854EFD433 v1
