Turning the Device On or Off
  • To turn the device on, press the power key Callout number one, or connect the device to power.
    Power button location with a callout
  • To put the device in power saving mode, press the power key while the device is on.
    While in power saving mode, the screen is off and the device uses very little power, but it can wake instantly for use.
    TIP: You can charge your device faster by putting it in power saving mode while charging the battery.
  • To turn off the device completely, hold the power key until a prompt appears on the screen, and select Off.
    The prompt appears after five seconds. If you release the power key before the prompt appears, the device enters power saving mode.
Copyright © Garmin. All rights reserved.GUID-1FBAE37F-A16E-441B-9E2D-F98F57D6EA68 v2
