Intercom System (ICS)
The intercom system (ICS) connects the pilot, copilot, and passengers. The intercom allows for quick isolation of audio from other positions by touching the corresponding Isolate Button (Pilot, Copilot, Passengers, Pilot Isolate, Crew Isolate, Pilot ISO, Crew ISO, etc.). The selected intercom volume level can be adjusted from 0 to 100% by touching the Volume Button then sliding your finger right or left on the slider. Sliding to the right increases volume, sliding to the left decreases volume.
AXIS™ flight displays internal audio panel ICS operates with a “opt in” methodology. This means that to be part of the ICS a user must “opt in” by activating the position’s (Pilot, Co-pilot, or Passenger when configured) button. Once a position is selected (a green indication on the button indicates that position is opted in) the position will be highlighted with a glowing green outline in the ICS summary image on the audio panel page. When users are not opted in to the audio panel, they will be considered “isolated” and will not be able to talk to other members of the aircraft over the ICS.
128: Intercom Controls
190-03123-21 Rev B
October 2026
