Simultaneous COM Operation
The pilot and the copilot are able to transmit and receive simultaneously over separate COM radios if the 'Split COM' function is enabled in the Audio Panel Menu. The selected COM MIC Annunciation flashes when either pilot’s microphone PTT is pressed.
For single pilot aircraft the 'Split COM' function will remove aural alerts from the passenger and co-pilot headsets. In dual pilot aircraft the 'Split COM' function will isolate all aural alerts to only be heard on the pilot headsets.
Parent Topic: Internal Audio Panel
