Positioning Sensors
The system accommodates aircraft positioning using the GPS sensors. When power is applied to the system, each sensor is enabled. Each sensor is continuously monitored and compared by the system, ensuring the most accurate source is in use. When a sensor is in use, ‘Used’ will be its displayed status. See the GPS Receiver Operation in the System Overview Section for details on SBAS, sensor receiver information, and RAIM prediction.
Table 31: FMS Sensors
FMS Sensor
Description
GPS 1
Garmin GPS Sensors
GPS 2
Sensors may be manually inhibited and re-enabled at any time. The annunciation bar on each sensor button will be displayed as green when the sensor is enabled, and gray when inhibited. Information on sensor failure and FMS degradation is discussed later in this section. Approach downgrade information is discussed previously in the Procedures portion of this section.
NOTICE
A sensor will not be monitored or used by the system once inhibited. Manually inhibiting sensors will affect the availability of position fixing modes.
190-03123-21 Rev B
October 2026
