G-Meter
Whenever the G load on the airplane goes above or below the configured settings, the HSI is temporally replaced with a large graphical G-meter. The G-meter can be deactivated in 'PFW Settings.' Regardless of the current G load, the HSI can be replaced with a G-meter by changing the ‘G Meter’ setting in 'PFW Settings.' If set to 'On', the G-meter will be displayed until the setting is changed to ''Auto', 'Off', or power is cycled. The G-Meter is also an option to be displayed on the PFD as a widget. For more information on how to set up widgets refer to the Enabling and Configuring Widgets on the PFD procedure of the System Overview chapter.
Small white triangles are used to indicate the minimum and maximum recorded G loads. When in the auto display mode, the G-meter will automatically be displayed when an unusual attitude is sensed (i.e., greater than +/- 65° roll or +30°/-20° pitch). Refer to the AXIS™ installation manual for more information on configuring the G-meter.
81: Automatic G-Meter Display
190-03123-21 Rev B
October 2026
