Adjusting Video Color Correction Parameters:
- Navigate to the 'Video' Application.
- Press the MENU Softkey (on the MFW side of the bezel if in split-screen mode).
Use the Brightness Horizontal Slider to adjust the Brightness.
Or:
Use the Contrast Horizontal
Slider to adjust the Contrast.
Or:
Use the Saturation Horizontal
Slider to adjust the Saturation.
NOTE: Use the DCK to adjust the setting by using the following steps.
- Push the DCK on the MFW side of the bezel if in split-screen mode.
- While the cyan outline is flashing, turn the Inner DCK clockwise to increase the setting and counter-clockwise to decrease the setting.
- Push the DCK again on the MFW side of the bezel if in split-screen mode to accept the change to the display setting.
Parent Topic: Auxiliary Video
