Unusual Attitudes
When the aircraft enters an unusual pitch attitude, red extreme pitch warning chevrons pointing toward the horizon are displayed on the Attitude Indicator, starting at 50° above and 30° below the horizon line.
102: Pitch Attitude Warning
If pitch exceeds +30°/-20° or bank exceeds 65°, some information displayed on the PFW is removed. While in an unusual attitude, the display will continue to provide a persistent indication of the ground (brown band or synthetic vision) in a nose down attitude, or sky (blue band) in a nose up attitude. The Altimeter, Airspeed, Attitude, Vertical Speed, and System Alert Window remain on the display and the Horizontal Situation indicator will be replaced by the G-meter (if G-meter is set to auto). The following information is removed from the PFW when the aircraft experiences unusual attitudes:
  • Navigation Information Window (below the HSI)
  • Traffic Annunciations
  • AFCS Annunciations
  • True Airspeed
  • ISA Temperature Deviation
  • Wind Data
  • Selected Heading Indication
  • Selected Course Indication
  • PFD Settings Windows Displayed on the PFD (MFW split-screen will remain)
  • Altimeter Barometric Setting
  • Minimum Altitude Alert Setting
  • Vertical Deviation, Glideslope, and Glidepath Indicators
  • Selected Altitude
  • VNAV Target Altitude
190-03123-21 Rev B
October 2026
