TAS/TCAS I Theory of Operation
When the traffic system is in Operating Mode, the system interrogates the transponders of other aircraft while monitoring for transponder replies. The system uses this information to derive the distance, relative bearing, and if reported, the altitude and vertical trend for each aircraft within its surveillance range.
The system then calculates a closure rate to each intruder based on the projected Closest Point of Approach (CPA). If the closure rate meets the threat criteria for a Traffic Advisory (TA), the system provides visual and voice alerting.
- Traffic Surveillance Volume
- TAS/TCAS I Symbology
- Traffic Symbology with Optional GTX
- TA Alerting Conditions
- System Status
Parent Topic: Traffic Avoidance
