Pairing a Bluetooth Device:
NOTICE
All devices will have the option to "Auto Reconnect' when the power is cycled.
Access the 'Bluetooth Settings' Window:
Access the Audio Panel by touching
the Audio Button on the CNS Bar at the top of the
display.
Or:
Touch the Applications Icon > Quick Actions Tab > Audio. ('Bluetooth Settings' may also be accessed through the 'Music' Window by touching the MENU Softkey.)
- Press the MENU Softkey on the side of the bezel the window is displayed.
- Touch the Connection Settings Button.
Or:
- Access the 'Apps' Window by touching the Applications Icon.
- If necessary, touch the Settings & Tools Tab.
- Touch the Connectivity Button.
- If necessary, touch the Bluetooth Tab.
- Touch the Settings Button in the Datalink Bluetooth section of the window.
display.
- Touch the Pair Device Button.
- A 'Pair Devices' window will open. The system may take several minutes to find available devices nearby.
- If necessary, scroll though the available devices to find and select the device you are trying to pair.
The flight display will present a six
digit code for verification with the device. Touch the OK
Button to begin pairing the device. An "Enable
Autoreconnect for [name of device]" will appear.
Touch the Yes
Button to connect to the device.
Or:
Touch the No Button to cancel the pairing process.
Touch the Yes
Parent Topic: Connext
