Deleting Waypoints from the Active Flight Plan:
  1. With the active flight plan open touch the waypoint button of the desired waypoint to be deleted.
  2. Touch the Remove Waypoint Button if the desired point is a waypoint.
  3. A confirmation window will appear. Touch the OK Button to remove the waypoint.
    Or:
    Touch the Delete Multiple Button to select multiple points for deletion.
    When multiple waypoints are selected for deletion, the system deletes the originally selected waypoint and all subsequent waypoints up to the last selected waypoint.
  4. Select the last waypoint in succession to be deleted.
  5. A confirmation window will appear. Touch the OK Button to remove the waypoints.
190-03123-21 Rev B
October 2026
