Exporting Logs
  1. Navigate to the 'Apps' Window:
    Touch the Applications Icon on the MFW.
    Or:
    Press the MENU Softkey two times.
  2. Touch the Settings & Tools Tab.
  3. Touch the Flight Data Button.
  4. If desired, change the export path by touching the Manual Export Path Selection Button and select the desired path for export.
    Touch the Export All Button to begin the export process of all data logs in the system.
    Or:
    Touch the Export Unexported Button to only export the data logs that have not yet been exported.
    Or:
    1. Touch the View All Button to view all data logs.
    2. Scroll the list of data logs as necessary and touch the data log that is to be exported.
    3. If desired, change the export path by touching the Manual Export Path Selection Button and select the desired path for export.
    4. Touch the Export Button.
  5. A confirmation window will open verifying the export should take place. Touch the OK Button to continue the export.
    Or:
    Touch the Cancel Button to cancel the export.
  6. After the export has begun, touch the Cancel Export Button to cancel all exports of the data logs.
190-03123-21 Rev B
October 2026
