Along Track Offsets
NOTICE
Initiating a Direct-to may remove the along track offset waypoint symbol from the map display if the along track offset waypoint is before the end of the direct-to segment. However, the along track offset waypoint will still remain in the flight plan. If it’s desired to have the along track offset waypoint redisplayed on the map, recreate the along track offset waypoint.
A waypoint having an “along track offset” distance from an existing waypoint can be entered into a flight plan. Along track offset waypoints lie along the path of the existing flight plan, and can be used to make the system reach a specified altitude before or after reaching the specified flight plan waypoint. Offset distances can be entered from 1 to 999 NM in increments of 1 NM.
Offset distance is calculated as a radial distance from the reference waypoint rather than a direct distance. The system will place the offset waypoint in the flight plan leg for which the radial distance intersects, regardless of distance between preceding flight plan legs.
Entering a negative offset distance results in an along track offset waypoint inserted before the selected waypoint, whereas entering a positive offset distance results in an along track offset waypoint inserted after the selected waypoint. Offset waypoints can span multiple flight plan legs, and multiple offset waypoints are allowed on each leg.
The system limits the along track offset distance so the along-track offset falls between the first and last waypoints in the flight plan. Assigning an along track offset to a leg with indeterminate length is not permitted. An along track offset is not allowed between the final approach fix and missed approach point of an approach.
An along track offset distance cannot be modified once entered. If the along track offset distance must be changed, the existing along track offset waypoint must be deleted and a new one created with the new offset distance.
Altitude constraints can also be entered for the along track offset waypoint within the flight plan or as part of a VNAV Direct-to. An along track offset waypoint can also be used for lateral navigation, such as the creation of a direct-to destination (discussed previously), or as a part of a user-defined hold (discussed later).
190-03123-21 Rev B
October 2026
