COM Error Messages
119: COM Error Message on CNS Bar
The following COM error messages may be displayed by the system if a COM fault exists:
Message
Description
Action
PILOT PTT STUCK
The Pilot Push To Talk key has been in the pressed position for at least 35 seconds. This key will now be ignored.
Verify Push To Talk key is not stuck. Refer to the installation manual for installation wiring tests. Contact Garmin for service if this message persists.
COPILOT PTT STUCK
The Copilot Push To Talk key has been in the pressed position for at least 35 seconds. This key will now be ignored.
BOTH PTT STUCK
Both Push To Talk keys have been in the pressed position for at least 35 seconds. This key will now be ignored.
Verify Push To Talk keys are not stuck. Refer to the installation manual for installation wiring tests. Contact Garmin for service if this message persists.
TX HARDWARE FAULT
An internal hardware problem is preventing COM transmission.
TEMP TOO HIGH
Internal temperature is too high.
Wait for unit to cool. Add supplemental cooling if problem persists.
SUPPLY VOLTAGE LOW
Supply voltage is too low.
Verify supply voltage meets minimum requirement identified in installation manual. Contact Garmin for service if message persists.
190-03123-21 Rev B
October 2026
