Charging the Handheld Device
NOTICE
To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer.
You should fully charge the battery before you use the device for the first time. Charging a fully depleted battery takes about 2 hours.
NOTE: The device will not charge when it is outside the charging temperature range (Specifications - Alpha 10).
  1. Lift the weather cap Callout number one.
    USB port and weathercap on the side of the device with callouts
  2. Plug the small end of the power cable into the USB port Callout number two on the device.
  3. Plug the other end of the power cable into a power source.
  4. After the device is fully charged, unplug the power cable from the device.
Copyright © Garmin. All rights reserved.GUID-1D417107-4752-4DBB-B711-BC3B010D1792 v2
