Disconnecting the USB Cable
If your device is connected to your computer as a removable drive or volume, you must safely disconnect your device from your computer to avoid data loss. If your device is connected to your Windows® computer as a portable device, it is not necessary to safely disconnect the device.
  1. Complete an action:
    • For Windows computers, select the Safely Remove Hardware icon in the system tray, and select your device.
    • For Apple® computers, select the device, and select File > Eject.
  2. Disconnect the cable from your computer.
Copyright © Garmin. All rights reserved.GUID-1D417107-4752-4DBB-B711-BC3B010D1792 v2
