Adding a Dog or Contact Using Wireless Pairing
  1. If the dog collar device is on, turn off the dog collar device (Turning Off the Device).
  2. Hold the power button on the dog collar device until the device emits two series of beeps (about 2 seconds), and then release the power button.
    The status LED flashes rapidly in green. The dog collar device is now ready to be linked, or paired, with a handheld device.
  3. On the handheld device, press the menu button.
  4. Select Add Device.
  5. Select an option:
    • If you are near the dog collar device, select Dog > Pair Collar, and follow the on-screen instructions.
    • To add a contact or dog collar device by receiving the information from another handheld device, select Receive Shared Asset.
      NOTE: To successfully add the contact or dog collar device, the other handheld device must be wirelessly sharing the information (Sharing a Dog or Contact Wirelessly).
  6. After successfully adding the device, enter the name of the dog or contact, and select Done.
Copyright © Garmin. All rights reserved.GUID-1D417107-4752-4DBB-B711-BC3B010D1792 v2
