Editing Dog Information
  1. From the tracking screen, select the dog you want to edit or select Device Options.
  2. Select Edit.
  3. Select an option:
    • Select Collar Light to change the collar light mode.
    • Select ID to change the dog collar device ID.
    • Select Update Rate to change how often position data is transmitted from the dog collar device.
    • Select Update Share Code to change the dog collar device share code.
    • Select Dog Type to set which alerts are sent from the dog collar device.
    • Select Battery Saver to turn battery saver mode on or off.
      NOTE: This automatically switches to a 2 minute update rate when the collar has 25% battery remaining.
    • Select Color to set the color used to identify the dog on external devices.
    • Select Collar Sleep Mode to turn collar sleep mode on or off.
      NOTE: When connected with the handheld device, the dog collar device can be put into sleep mode to conserve the battery when you are not actively tracking your dog.
    • Select Name to edit the name of the dog.
    • Select Remove to remove the dog from your device.
Copyright © Garmin. All rights reserved.GUID-1D417107-4752-4DBB-B711-BC3B010D1792 v2
