Composite Video Considerations
This chartplotter allows video input from composite video sources using the port labeled CVBS IN. When connecting composite video, you should observe these considerations.
  • The CVBS IN port uses a BNC connector. You can use a BNC to RCA adapter to connect a composite-video source with RCA connectors to the CVBS IN port.
  • Video is shared across the Garmin® Marine Network, but it is not shared across the NMEA 2000® network.
GUID-1D10BCD0-0E11-47B4-A319-12BED4E1FF9E v4
January 2025
