NMEA 0183 Device Connections
This diagram illustrates two-way connections for both sending and receiving data. You can also use this diagram for one-way communication. To receive information from a NMEA® 0183 device, refer to items Callout number 1, Callout number 2, Callout number 3, Callout number 4, and Callout number 5 when connecting the Garmin® device. To transmit information to a NMEA 0183 device, refer to items Callout number 1, Callout number 2, Callout number 3, Callout number 6, and Callout number 7 when connecting the Garmin device.
Wiring diagram with callouts
Item
Description
Callout number 1
Power source
Callout number 2
Power cable
Callout number 3
NMEA 0183 device
Callout number 4
NMEA 0183 cable
Item
Garmin Wire Function
Garmin Wire Color
NMEA 0183 Device Wire Function
Callout number 1
Power
Red
Power
Callout number 2
Power ground
Black
Power ground
Callout number 3
Data ground
Black
Data ground
Callout number 4
Rx/A (In +)
White/orange
Tx/A (Out +)
Callout number 5
Rx/B (In -)
White
Tx/B (Out -)
Callout number 6
Tx/A (Out +)
Gray
Rx/A (In +)
Callout number 7
Tx/B (Out -)
Pink
Rx/B (In -)
If the NMEA 0183 device has only one input (receive, Rx) wire (no A, B, +, or -), you must leave the pink wire unconnected.
If the NMEA 0183 device has only one output (transmit, Tx) wire (no A, B, +, or -), you must connect the white/orange wire to ground.
GUID-1D10BCD0-0E11-47B4-A319-12BED4E1FF9E v4
January 2025
