Specifications
Dimensions (W × H × D)
33.0 × 22.6 × 7.9 cm (13.0 × 8.9 × 3.1 in.)
Display size (W × H)
26.2 × 16.3 cm (10.3 × 6.4 in.)
12.1 in. diagonal
Weight
2.72 kg (6.0 lb.)
Clearance to nearest obstruction
95 mm (33/4 in.)
Compass-safe distance
65 cm (25.6 in.)
Temperature range
From -15° to 55°C (from 5° to 131°F)
Material
Die-cast aluminum and polycarbonate plastic
Water rating
IEC 60529 IPX7
*The device withstands incidental exposure to water of up to 1 m for up to 30 min. For more information, go to www.garmin.com/waterrating.
Fuse
6 A, 125 V fast-acting
Input voltage
From 10 to 32 Vdc
Max. power usage at 10 Vdc
36 W
Typical current draw at 12 Vdc
2.4 A
Max. current draw at 12 Vdc
3.0 A
NMEA 2000® LEN @ 9 Vdc
2
NMEA 2000 Draw
75 mA max.
Memory card
2 SD® card slots; 32 GB max. card size
Wireless frequency and protocols
2.4 GHz @ 15.26 dBm
GUID-1D10BCD0-0E11-47B4-A319-12BED4E1FF9E v4
January 2025
