Pairing Your Wireless Sensors
Before you can pair, you must put on the heart rate monitor or install the sensor.
The first time you connect a wireless sensor to your device using ANT‍+® or Bluetooth® technology, you must pair the device and sensor. If the sensor has both ANT‍+ and Bluetooth technology, Garmin® recommends that you pair using ANT‍+ technology. After they are paired, the Edge® bike computer connects to the sensor automatically when you start an activity and the sensor is active and within range.
NOTE: If your device was packaged with a sensor, they are already paired.
  1. Bring the device within 3 m (10 ft.) of the sensor.
    NOTE: Stay 10 m (33 ft.) away from other riders' sensors while pairing.
  2. Select Menu symbol > Sensors > Add Sensor.
  3. Select an option:
    • Select a sensor type.
    • Select Search All to search for all nearby sensors.
    A list of available sensors appears.
  4. Select one or more sensors to pair with your device.
  5. Select Add.
    When the sensor is paired with your device, the sensor status is Connected. You can customize a data field to display sensor data.
GUID-17DE938E-466A-4746-BDBF-7A6FC1B3A32C v3
July 2024
