Mounting Considerations
NOTICE
This device should be mounted in a location that is not exposed to extreme temperatures or conditions. The temperature range for this device is listed in the product specifications. Extended exposure to temperatures exceeding the specified temperature range, in storage or operating conditions, may cause device failure. Extreme-temperature-induced damage and related consequences are not covered by the warranty.
  • You must mount the device in a location where it will not be submerged.
  • You must mount the device in a location with adequate ventilation so it does not trap heat.
  • You must mount the device at least 2.54 cm (1 in.) from cables and other potential sources of interference.
  • You must mount the device in a location that allows room for the routing and connection of all cables.
GUID-16AB9F2E-6D52-48FF-BCCC-C0633F54CC95 v2
August 2024
