Routing Settings
The available routing settings vary based on whether Direct Routing is enabled or disabled.
Select Tools symbol > Routing.
Direct Routing
Enables or disables direct routing. Direct routing calculates the most direct route possible to the destination.
Activity
Sets an activity while routing. The device calculates routes optimized for the type of activity you are doing.
Calculation Method
Sets the method used to calculate your route.
Lock On Road
Locks the blue triangle, which represents your position on the map, onto the nearest road. This is most useful when driving or navigating on roads.
Off Route Recalculation
Sets recalculation preferences when navigating away from an active route.
Avoidance Setup
Sets the types of roads, terrain, and transportation methods to avoid while navigating.
Route Transitions
Sets how the device routes from one point on the route to the next. This setting is available only for some activities. The Distance option routes you to the next point on the route when you are within a specified distance of your current point.
GUID-1515D6D5-8276-4A9E-A7A1-64A97160D31A v2
October 2025
