Calibrating the Barometric Altimeter
You can calibrate the barometric altimeter manually if you know the correct elevation or the correct barometric pressure.
  1. Go to a location where the elevation or barometric pressure is known.
  2. Select Track Manager > My Track > Elevation plot > Menu > Altimeter Setup > Calibrate Altimeter.
  3. Follow the on-screen instructions.
GUID-1515D6D5-8276-4A9E-A7A1-64A97160D31A v2
October 2025
