The tilt bracket connects to the jack plate bracket and allows you to rotate your transducer
for different viewing modes.
Place the tilt bracket against the jack
plate bracket so that the holes align for your preferred configuration:
- To mount your transducer in perspective mode, center the holes with the slots
marked with P.
- To mount your transducer in downward mode, center the holes with the slots marked
with D.
Locate three 20 mm bolts and three 6 mm
washers in the bag labeled
Place the washers on the bolts . .
Use the bolts to secure the tilt bracket
to the jack plate
bracket .
NOTE:
For now, finger-tighten the bolts. Do not fully tighten them at this time.
