Tightening the Bolts
After you have oriented the transducer in your preferred viewing mode, you must fully tighten each bolt to the specified torque.
NOTICE
You must tighten each bolt to the specified torque. Over- or under-tightening the bolts can result in damage to the transducer or jack plate mount.
  1. Using a torque wrench, tighten the two larger 8 mm bolts to 20 N-m (15 lbf-ft.).
  2. Tighten the nine smaller 6 mm bolts to 9 N-m (6.5 lbf-ft.).
You should regularly inspect the jack plate mount for loose bolts, and tighten them as needed.
GUID-1492D076-511B-4A9A-9FF1-C8C50EA630BA v1
October 2026
